Post by zummerp on Mar 16, 2018 15:54:07 GMT -5
For anyone who doubts the importance of frequent oil changes during the break in period of these GY6 engines, I changed this before I put any miles on it and just changed it again today at 50 miles. Look at this beautiful black sludge! Also I didn’t take any pictures but my Prima magnetic drain plug was covered in little metal shavings, so I’m calling that a worthwhile $13 upgrade!
Post by sw6456 on Mar 16, 2018 15:55:28 GMT -5
For anyone who doubts the importance of frequent oil changes during the break in period of these GY6 engines, I changed this before I put any miles on it and just changed it again today at 50 miles. Look at this beautiful black sludge! Also I didn’t take any pictures but my Prima magnetic drain plug was covered in little metal shavings, so I’m calling that a worthwhile $13 upgrade! Interesting, may need to look into a magnetic drain plug now while i’m already replacing some things
Post by zummerp on Mar 16, 2018 16:02:27 GMT -5
Post by lilpinny on Mar 16, 2018 16:09:01 GMT -5
I use that kit too. Just make sure you keep your washer/gaskets from your old bolts.
Post by sw6456 on Mar 16, 2018 17:41:35 GMT -5
Thanks, I’ll pick one up and thanks for the reminder
Post by zummerp on Mar 16, 2018 19:54:15 GMT -5
I use that kit too. Just make sure you keep your washer/gaskets from your old bolts. Uh oh - which one is supposed to have a gasket?!!
Post by lilpinny on Mar 16, 2018 20:20:55 GMT -5
The gear oil drain bolt has one on my GY6. It'll leak on me without it. I think the motor oil drain has one too, but I've left that one off and not had a problem.
Post by lilpinny on Mar 16, 2018 20:30:47 GMT -5
They call it a gasket, I call it a washer
Post by fuzzyruttin on Mar 16, 2018 20:38:26 GMT -5
that amazon link is for QMB139, assuming it'll fit gy6 150? thanks for the post, will look into considering my gy6 < 50 miles (i think)
Post by zummerp on Mar 16, 2018 20:48:14 GMT -5
They call it a gasket, I call it a washer I have washers on each - just making sure I wasn’t missing something
Post by lilpinny on Mar 16, 2018 20:49:44 GMT -5
I've chucked the old bolts before, washers still in them when installed the kit the first time. Found out the hard way they need to be there 🙃
Post by fuzzyruttin on Mar 28, 2018 19:27:20 GMT -5
For anyone who doubts the importance of frequent oil changes during the break in period of these GY6 engines, I changed this before I put any miles on it and just changed it again today at 50 miles. Look at this beautiful black sludge! Also I didn’t take any pictures but my Prima magnetic drain plug was covered in little metal shavings, so I’m calling that a worthwhile $13 upgrade! Thanks for this thread... inspired me to change oil with under 100 miles on GY6 150. Ewww:
Post by GrumpyUnk on Mar 31, 2018 11:42:57 GMT -5
Was that the factory installed oil? Remember that if this is a new engine, or one that has new rings/piston/cylinder or similar, the rings won't seal their best for a while, and you likely will get more unburned contaminants for a wile, including carbon from partially burned fuel. The color should improve over time, and cause a lot less discoloration as the rings seat better. My sense is that your rings have not seated, or you are in a colder climate where the 'choke/enricher' is engaged for a longer percent of running time, or you make a lot of short trips. If so, you might want to consider changing the oil more often than is recommended. Otherwise, if things don't improve after 5-600 miles or so, and the oil gets black quickly, I'd want to check that the rings are working by doing a compression test. Or, if you are satisfied with the way it run, just keep changing oil more ofen. The color does NOT hurt anything. It is actually carbon particles, which can act as graphite, as used in lock cylinders for dry lubricant. Arco, Union 76, or Chevron or ??? at one time sold oil that looked exactly like that when you poured it into your engine. Memory as to the exact name is not there. So even the 'oil guys' saw no problem with it, FWIW. tom
Post by fuzzyruttin on Mar 31, 2018 14:46:04 GMT -5
^ no, i drained what oil was in the engine from the factory. The guy i got the kit from delivered it with a quart of BelRay mineral 10-40. That's what you're looking at after 100 miles on fresh engine. Couldn't find anyone that sells that oil locally, so ended up buying Royal Purple break-in engine oil. It's got zync to help the rings seal better. So, couple more thousand miles n then switch to something normal. That's the plan anyway.
