Post by zummerp on Mar 18, 2018 7:26:11 GMT -5
Hey guys - when I remove my carb on my ATM50-A1, I get a gas waterfall that is tricky to stop. I've tried using the drain screw but it just continues to drain my tank if I open it. What am I doing wrong? Thanks!
Post by 90GTVert on Mar 18, 2018 8:47:52 GMT -5
You need to have some sort of fuel shutoff. They usually have a vacuum petcock stock, that shuts the fuel supply off when the engine isn't running. If that's working properly, you should only drain what fuel is in the bowl so it shouldn't continue to drain for long. Maybe someone modified it? If so, you should put a manual shutoff inline. 49ccscoot.proboards.com/thread/18187/vacuum-petcock-manual-conversion
