Post by sw6456 on Mar 19, 2018 10:15:28 GMT -5
I was wondering if anyone knew what screws I would need to buy for the carburetor float bowl on the carburetor because I stripped the heads on mine getting them off the first time since they apparently had to torque them down as much as they could
Post by 90GTVert on Mar 19, 2018 11:34:25 GMT -5
I used M4x0.7x14 screws in mine.
Post by jackrides on Mar 19, 2018 12:17:59 GMT -5
A previous post talked about metal corrosion and stated that cadmium plated (sort of a gold color) resisted best. I'll add otherwise put a bit of anti seize on each thread.
Post by zummerp on Mar 19, 2018 12:34:10 GMT -5
I couldn't find M4x0.7x14 at Home Depot, but they DID have M4x0.7x16 which fit just fine along with matching M4 lock washers.
Post by GrumpyUnk on Mar 19, 2018 15:19:24 GMT -5
When I could not get the screws to let loose, I used a small Vise-Grip clamped onto the side of the screw head. Vise-grip makes a very small size that is muy handy to have. I think I use it more than the larger sizes, FWIW. If you don't ride in a salty area, and don't go way overboard tightening the fasteners, you should not have much problem removing them in the future even without anti-seize. I would recommend using split lock washers as fitted originally on some. tom
Post by pinkscoot on Mar 19, 2018 15:34:03 GMT -5
