Post by mrkswthwrth on Mar 25, 2018 12:10:16 GMT -5
So my TTR50 only has the side stand, no center stand. However being a 230lb bike and me having a cobblestone driveway, well.. i now have a bent brake lever and a scratched fender 😨
Are all gy6 50 4t center stands interchangable? If do where can i get one cheap hah. Thanks yall
Post by zummerp on Mar 25, 2018 13:56:01 GMT -5
So my TTR50 only has the side stand, no center stand. However being a 230lb bike and me having a cobblestone driveway, well.. i now have a bent brake lever and a scratched fender 😨 Are all gy6 50 4t center stands interchangable? If do where can i get one cheap hah. Thanks yall I bought mine from ScooterWorks.com - the picture below shows all the pieces I bought. It worked perfect and was surprisingly easy to install once I figured out the screwdriver trick
Post by jackrides on Mar 25, 2018 14:37:27 GMT -5
On the 10" wheel Taotaos, the center stand will scrape in a moderate left turn. I like the centerstand, so... I replaced the rubber bumper with a carriage bolt with the head having several coats of Plasti-dip on it. (So the stand will go up farther). Ground a LITTLE off the bend where it touches down, and repainted it. Helps a little. Why? If something drags in a corner and you try to lean farther, it can lever the rear tire off the ground and bad things happen.
Post by mrkswthwrth on Mar 26, 2018 15:38:55 GMT -5
Thanks for the tip boss! I have a 12" wheel in back and a 17" wheel up front so i should be safe, but when i get around to installing one ill be sure to check for clearance before i go too crazy in the twisties
