Post by katt on Apr 14, 2018 22:16:08 GMT -5
Based on VIN lookup its made by JIANGSU BAODIAO LOCOMOTIVE CO., LTD. in 2011. Probably very close to this one they make From description Maximum weight capacity: 75kg i am 90kg is that fine?
Post by 90GTVert on Apr 15, 2018 5:50:42 GMT -5
You should be fine. Not sure why they'd rate it at only 75kg. You can find various specs at different brand sites, even though they may have been from the same assembly line. Sometimes I think they just pull numbers out of the air.
Post by katt on Apr 16, 2018 17:42:12 GMT -5
As far as i know for the cars weight rating is made for brakes. If you load more braking efficiency gets lower. Another reason for lower weight rating i guess is that design where rear wheel is NOT connected to frame or either side, but to the engine weak aluminum body. Only points that connect rear wheel to the frame are shocks. I don't think i will be keeping this scooter design does not feel very safe, i rather get dirt bike.
