Post by cripley on Apr 10, 2018 18:08:53 GMT -5
I had this scooter given to me. I can not find any manuals online or where I would get parts for it. It runs, I put a new battery in but the battery will not start the scooter. I push the start and the battery seems to run out of power and is not able to start it, so I kick start it instead. I need a new dash as none of the gauges work (or an idea on what to do). If anyone has any information on this scooter I would appreciate the help.
Post by 90GTVert on Apr 10, 2018 20:41:52 GMT -5
If you can post a pic of it or any more info, maybe we can help you find parts. Very many Chinese scoots are quite similar, but get re-branded so much that their less common names aren't easily recognized.
Does the battery run out of power very quickly or after extended cranking?
Post by cripley on Apr 12, 2018 15:37:58 GMT -5
Dogbite
Chinese scooter Hacker
Post by Dogbite on Apr 18, 2018 7:46:43 GMT -5
This is what i found and there is a picture also but I could not copy it.I found some other stuff around 2005 year and thats probably the vintage of that style.
Model No: JM50QT-B2 This model scooterb have passed EC and EPA certificate Scooter
Detailed Product Description Product Description: Dimension(LXWXH): 1660�700�1070mm Max speed: 45km/h Engine type: 1-cylinder, 4-stroke Displacement: 49.58ml Maxed power and rotate speed: 2.0kW/7500rpm Max torque and rotate speed: 3.0 N.m/6500rpm Unloaded weight: 74kg Gearshift mode: automatic Starting system: Electric/kick back Stroke: 4-stoke Fuel tank: 4L Economic fuel consumption: 1.8L/100km Ignition: CDI Model No.: JM50QT-B2 Product Origin: QINGDAO, CHINA Brand Name: JINMA Price Terms: FOB QINGDAO , CIF Payment Terms: T/T, L/C Supply Ability: 500/ one month Delivery Lead Time: 20 Certification(s): EC, ISO9001
Post by cripley on Apr 22, 2018 13:11:29 GMT -5
Thank you, that says it’s a 4 strike, but I def have a 2 stroke. Also, the kick start wouldn’t work it would make same noice as electro start. Once charged the scooter started, when I checked the battery the bolts bounced all over the place. Does this sound like a voltage regulator problem? I have some pictures of it all torn apart and would like to know what some of the parts are. I will post those when I get to a computer.
Post by maker1to2 on Apr 24, 2018 0:36:54 GMT -5
looks like it could be a jog clone...looks just like a rexy might have to check the engine to see if it hor or long engine and also check if the transmission is chain or belt drive...looks like the companys name is Qingdao DaJinma...Jinma for short! this company sales a Jinma Bomb style scooter. they might can get you parts or more information about your scooter www.saferwholesale.ca/Brand-New-Mini-Roadster-Moped-Jinma-Scooter-p/msp-minijinma.htm
Post by cripley on Apr 29, 2018 22:14:49 GMT -5
Obviously I know one is the voltage Regulator, another is a relay what is the black thing though?
Post by maker1to2 on Apr 30, 2018 16:09:10 GMT -5
Looks like ignition coil. Is the wire that is extending from it connecting to the spark plug? Also by the looks of the coil and placement you have a 4 stroke.
Post by maker1to2 on Apr 30, 2018 16:12:57 GMT -5
Also charge your battery..side note try using your car or truck battery to start your bike.
Post by cripley on May 3, 2018 19:58:43 GMT -5
It does travel to the spark plug, can I swap that with one of the many different ignition cables there are? How would I do so?
Post by 90GTVert on May 6, 2018 7:53:10 GMT -5
It does travel to the spark plug, can I swap that with one of the many different ignition cables there are? How would I do so? These are usually a copper core style that screw on and off of the caps and coils.
Post by cagiva4ever on May 6, 2018 17:06:31 GMT -5
2-stroke engine like: 50cc 1PE40QMB. Vertical cylinder. bore diam mots likely 40mm.
have a look for that said engine code and look for carb photo and compere it against by yours (as i cant see more from your photos, but i see the carb and its Orientation ! )
that said engine is used on some Taiwanise CPi's.
if yours is same, then engine parts are Secured available plenty. also electricals and wiringloom parts are Generic available.
only your model specific parts left are then frame and fairing parts/tachos/suspension and rims.
