Post by gabito503 on Apr 16, 2018 7:13:33 GMT -5
my 72cc bbk vibrate so bad In the morning!!
Post by 90GTVert on Apr 16, 2018 7:21:39 GMT -5
I assume this is a four-stroke 139QMB? Is it just that it idles low perhaps when it's cold?
Post by gabito503 on Apr 16, 2018 8:25:45 GMT -5
yes 139qmb everything was gine the vib just start this morning. after 10mnts running stops
Post by mrkswthwrth on Apr 16, 2018 11:47:24 GMT -5
So it only does it on a cold start until it gets up to operating temperature?
Post by dexameth on Apr 17, 2018 8:48:04 GMT -5
She must not be a morning scoot. Have you tried making a good cup of coffee for her first?
Post by GrumpyUnk on Apr 18, 2018 18:50:44 GMT -5
I would check the valve clearance adjustment. It has been long enough for the clearances to close up a bit, which could cause a poor idle. One other cause is water in the fuel. Has it been raining a lot or cold damp weather that would allow condensation to form in the tank? Normally water would cause intermittent misfire at speed also. tom
Post by gabito503 on Apr 30, 2018 20:50:49 GMT -5
thank guys for help!!!💪🏻💪🏻💪🏻 I put 93 octa gas and runs perfect now
