Post by snakeplissken on Apr 22, 2018 15:40:32 GMT -5
Hey nice to be back for another year of riding my scooter. Does anyone know where i can buy idle jets and needles for a Dellorto PHVB 22mm carb Model: M1611031 that i can buy here in USA. I can only find Euro sellers. The carb has "W" needles and 15500 idle jets.
Post by moofus02 on Apr 22, 2018 16:05:35 GMT -5
Try treatland.tv
Post by snakeplissken on Apr 22, 2018 16:26:41 GMT -5
Nice site but not enough parts for the PHVB carb. I see they had the W needles but they were listed for a PHGB carb.
Post by ThaiGyro on Apr 23, 2018 5:48:05 GMT -5
Scooterworks...https://www.scooterworks.com/Pinasco-Carburetor-22mm-ApriliaPiaggioVespa-P7583.aspx Scootertronics...http://www.scootertronics.com/about-us.html
Post by snakeplissken on Apr 24, 2018 14:05:51 GMT -5
Scooterworks...https://www.scooterworks.com/Pinasco-Carburetor-22mm-ApriliaPiaggioVespa-P7583.aspx Scootertronics...http://www.scootertronics.com/about-us.html I checked don't see anything but the carb for sale.
Post by geoffh on Apr 24, 2018 15:25:31 GMT -5
If the Euro sellers won,t ship to the USA I,m UK based and happy to help out but it could take a while geoff
Post by Lucass2T on Apr 25, 2018 5:31:11 GMT -5
You need the M type needles and dellorto 6mm jets. PHBG = 5mm.
You might be able to use TK (TeiKei) carb jets since TK carbs take dellorto 6mm jets.
On my 70mph Yamaha Axis i have a 20.5mm PHVB, on the stock axis motor is a 14mm TK carb. I recently found out those take dellorto jets right away, plug and play!
Post by snakeplissken on Apr 25, 2018 8:49:54 GMT -5
If the Euro sellers won,t ship to the USA I,m UK based and happy to help out but it could take a while geoff Thanks for the offer. I can get them shipped from the UK but was hoping to find a supplier here in the states.
Post by snakeplissken on Apr 25, 2018 8:52:49 GMT -5
You need the M type needles and dellorto 6mm jets. PHBG = 5mm. You might be able to use TK (TeiKei) carb jets since TK carbs take dellorto 6mm jets. On my 70mph Yamaha Axis i have a 20.5mm PHVB, on the stock axis motor is a 14mm TK carb. I recently found out those take dellorto jets right away, plug and play! I'll look into it. I also read the carb takes M needles but i took the needle out and it says W 25 on it. Don't understand. It has H45 idle jet but when it comes to the needle it's a "W" needle. Go figure
Post by Lucass2T on Apr 25, 2018 9:31:46 GMT -5
You need the M type needles and dellorto 6mm jets. PHBG = 5mm. You might be able to use TK (TeiKei) carb jets since TK carbs take dellorto 6mm jets. On my 70mph Yamaha Axis i have a 20.5mm PHVB, on the stock axis motor is a 14mm TK carb. I recently found out those take dellorto jets right away, plug and play! I'll look into it. I also read the carb takes M needles but i took the needle out and it says W 25 on it. Don't understand. It has H45 idle jet but when it comes to the needle it's a "W" needle. Go figure When your PHVB has a W needle, than thats completely the wrong one! They're way to short for the PHVB and don't have the boss at the top which secures it in the slide!
Mine came with a M5 Needle stock I think.
Post by snakeplissken on Apr 30, 2018 10:54:23 GMT -5
The Needle seems to fit. When i get a chance Ill take it out and snap a pic of the needle.
Post by snakeplissken on May 3, 2018 10:09:02 GMT -5
Here a couple of pics of the needle
Post by Lucass2T on May 4, 2018 4:00:12 GMT -5
You need this needle:
Post by snakeplissken on May 4, 2018 8:54:44 GMT -5
While the carb is a dellorto PHVB The one i got was a Malossi branded one. Same carb just sold by Malossi. Here i found this post where the person describes that the carb has a W25 needle. All the other specs were right but the needle. scootercommunity.com.au/forums/t/10076.aspx
