Post by magoconnor on Apr 24, 2018 18:21:42 GMT -5
Hello. Can anybody tell me if you can use keihin pwk main jets, on a keihin cvk carburetor?
They are both 4mm.
Post by mrkswthwrth on Apr 24, 2018 20:11:59 GMT -5
Should work if thread diameter and pitch are the same...
Post by magoconnor on Apr 24, 2018 20:51:39 GMT -5
The diameter is the same, but what is the pitch?
Post by mrkswthwrth on Apr 24, 2018 21:16:03 GMT -5
Should be 4mm x 0.7mm for any 4mm jet.. the tillotson carb on my 71 skidoo has 4mm jets and they're .7mm pitch.
However it may be the exception not the rule.
Best bet is to get a jet from each carb and measure it yourself, from peak to peak of the threads with a caliper.
Post by ryan_ott on Apr 24, 2018 21:20:03 GMT -5
I believe the PWK main jets will thread into the cvk but the PWK uses hex jets which are longer thenthe round jets the cvk uses. In a pinch you can make them work but if ordering jets just get the correct ones.
Post by magoconnor on Apr 24, 2018 21:33:27 GMT -5
My bad... My carburetor is a cvk. I misunderstood my local dealer, I thought he said they would fit a pwk carb, but what he actually said was that they would fit a puch P+k carb... They are still 4mm looks almost the same as the keihin jets. I wonder if they would work? He is a link to the ones I'm talking about: www.thansen.dk/product.asp?n=1709621276&pn=1709622525
Post by magoconnor on Apr 24, 2018 22:27:51 GMT -5
I have compared them side by side. The have the same total length. Same thread count.
Post by magoconnor on Apr 25, 2018 7:51:18 GMT -5
The "real" difference between the two, is I think, that the funnel inside the jet sits a little lower. On the side with the threads. Will this have any impact ? Otherwise they share the exact the same measurements.
Post by 90GTVert on Apr 25, 2018 11:40:12 GMT -5
I don't think it would be a great idea to mix and match for tuning, because they may perform differently. Aside from seeing the difference in the orifice, companies may rate their jets in a different manner. So, if this is say a 70 then I wouldn't assume that a 70 in the other style is the same. Even buying jets intended for the same application, sometimes they don't match that way and it can cause problems when tuning. Best bet IMO is to get a full set of jets in the closest style you can find from the same manufacturer.
