First 4t
Apr 29, 2018 17:43:08 GMT -5
via mobile
Post by jdl357 on Apr 29, 2018 17:43:08 GMT -5
Just bought my first 4 stroke scoot yesterday. It hasn't been run in a year, so I want some advice on what to check, change, and clean to get it running again. Thanks.
Post by scootnewb on Apr 29, 2018 17:54:50 GMT -5
Check the fuel in the tank and drain and replace if it is old. If the battery wasn't removed while it was sitting, you may need to charge it via an external charger or even replace it. Check the fuel and vacuum lines for leaks and cracks. Check plastic intake that connects carb to head and fuel filter. Replace any of those if needed. Check and clean spark plug and air box filter.
I guess you could check to make sure the valve clearance is good too.
EDIT:
You can also check to see if the vacuum petcock is working. If fuel line fuel filter is NOT clogged, remove the fuel line that goes to the carb and kick start it. Did gas come out? If not you may want to get a new one or just get a manual petcock.
What kind of scoot is it?
First 4t
Apr 29, 2018 20:55:06 GMT -5
via mobile
Post by jdl357 on Apr 29, 2018 20:55:06 GMT -5
Thanks, it's a 2007 Kymco People S 50
Post by scootnewb on Apr 30, 2018 1:07:46 GMT -5
Nice. Are you going to do the BBK and other mods?
Post by pinkscoot on Apr 30, 2018 8:37:31 GMT -5
Clean the carb and check the CVT, everything you would do to a 2T thats been sitting except checking the valves.
First 4t
Apr 30, 2018 14:16:14 GMT -5
via mobile
Post by jdl357 on Apr 30, 2018 14:16:14 GMT -5
I got her running well enough to drive it home from where I bought it just now. I'm definitely going to do a bbk and an A9 camshaft is what I'm hearing works well. It sure doesn't have the pep that my 2 stroke does! But I'll see if I can't fix that!
First 4t
Apr 30, 2018 14:28:56 GMT -5
via mobile
Post by jdl357 on Apr 30, 2018 14:28:56 GMT -5
What's the biggest bbk I can do without case boring? 47mm, 50mm, 52mm?
Post by benji on Apr 30, 2018 14:42:05 GMT -5
I got her running well enough to drive it home from where I bought it just now. I'm definitely going to do a bbk and an A9 camshaft is what I'm hearing works well. It sure doesn't have the pep that my 2 stroke does! But I'll see if I can't fix that! I don't think you can fix that haha. Nothing accelerates like a 2t. Although my metro has some nice grunt off the line.
Post by 90GTVert on May 1, 2018 19:02:06 GMT -5
What's the biggest bbk I can do without case boring? 47mm, 50mm, 52mm? The Naraku 52.4mm I have is the same diameter at the skirts as the generic 50mm I have, and they fit most without boring. There are some older scoots, maybe others around, that wouldn't usually fit 50mm kits. www.49ccscoot.com/faq/whichkit.html
Post by scootnewb on May 1, 2018 20:59:59 GMT -5
I love 2 strokes. Once I learn more I am going to drop one of these in the Taotao 50 You know it would be sick. EDIT: Perhaps 90GTVert can do it first and write out a step by step?
Post by Happypancake! on May 1, 2018 21:39:06 GMT -5
I got her running well enough to drive it home from where I bought it just now. I'm definitely going to do a bbk and an A9 camshaft is what I'm hearing works well. It sure doesn't have the pep that my 2 stroke does! But I'll see if I can't fix that! I don't think you can fix that haha. Nothing accelerates like a 2t. Although my metro has some nice grunt off the line. Keep tuning that “grunt”. 4t will outrun 2t in the long run.
Post by GrumpyUnk on May 2, 2018 12:15:13 GMT -5
If it starts and runs without fiddling with the throttle, your carb should be good to go. I think I would drop the float bowl any way, to make sure there is nothing floating around that might get sucked into the jets, or there's sediment that is high enough to possibly block the jet. tom
