Post by magoconnor on May 1, 2018 15:08:05 GMT -5
Hello.
Will it be okay to run without the black intake spacer?
Setup 72cc gy6. stock carb. Bvh.
Post by 90GTVert on May 2, 2018 8:12:37 GMT -5
Why?
You're better off with it I think. It's an isolator that helps to keep engine heat out of the intake/carb. If port size is the issue, it's prob the easiest part to port match.
