Post by mlos55 on May 4, 2018 15:40:27 GMT -5
I was cleaning my carb when I tried to unscrew idle jet to clean it but jet both with atomizer started to spin in carb housing. So I pulled them out. I bought epoxy to set them in but I don't know in what position to put atomizer. There is one direction with one hole and other direction with two holes, placed in 90 deg angle. And there is only one hole in carb housing. So I don't know how to aling it, with one or with two holes on atomizer. You will better understand me on pictures.
Post by 190mech on May 4, 2018 20:04:50 GMT -5
It doesnt matter which way it goes back in...
Post by mlos55 on May 5, 2018 4:18:51 GMT -5
It doesnt matter which way it goes back in... Yeah I just read about atomizers and it says that air that is coming from air/fuel mixture screw is spinning around holes on atomizer in that dent, like making turbulence, not actually entering holes. And that regulate fuel that is entering on idle, like you unscrew more air/fuel screw, more air comes in, higher turbulence and then less fuel is mixing. Interesting But thanks anyway
Post by 190mech on May 5, 2018 5:32:05 GMT -5
Right,I always viewed a carb as a spray paint gun as both mix air with liquid to atomize the mixture..
