Post by magoconnor on May 8, 2018 16:30:04 GMT -5
Does this look okay?
Post by scootnewb on May 8, 2018 17:53:16 GMT -5
I think it is running good to lean?
Post by magoconnor on May 8, 2018 18:56:01 GMT -5
its really hard to tell, im running with a 105 main jet. Setup 72cc with a Bvh. Performance cam. Free flow air filter with a 20cm intake runner.
Post by magoconnor on May 8, 2018 18:56:22 GMT -5
Stock Carb.
Post by viaqua on May 8, 2018 19:56:03 GMT -5
Looks ok to me..
Post by magoconnor on May 9, 2018 8:02:08 GMT -5
It has a sort of dull grey color to it, with a little tan in the center on the white porcelain.
Post by jackrides on May 9, 2018 9:47:25 GMT -5
A little lean.
Post by magoconnor on May 9, 2018 9:54:44 GMT -5
Ok thanks, I will try a 108 main jet and see what happens.
Post by magoconnor on May 9, 2018 10:14:52 GMT -5
Hi again. Could you maybe take a look at my other bike? Here are some fresh pictures:
Post by jackrides on May 9, 2018 12:09:14 GMT -5
Lean.
Post by magoconnor on May 9, 2018 13:02:07 GMT -5
damn... you think so? I tried blocking off a part of the filter with tape, and that made the bike run worse.
Post by magoconnor on May 9, 2018 18:44:23 GMT -5
Hello. I tried swapping the plug on "the other bike" (the second set of pictures) was with a 110 main jet. So I tried swapping it out for 120 main jet. I was unable to give it any throttle without it just dying. So I ripped the 120 jet out and replaced it with a 115 main jet. The bike ran much better, but there still is some hesitation upon accerleration. Sometimes it feels very strong, other times it feels less motivated to feed me the rpms I need. Here are some pictures of the 115 main jet:
Post by magoconnor on May 9, 2018 18:50:44 GMT -5
Top end could also be a little bit better.
Post by scootnewb on May 9, 2018 19:22:05 GMT -5
Wow. Maybe it is the BVH but 115 seems big. It's too bad nobody has created a list of what jet for what mods. But your posts have made me think I need to go way bigger in main jet size with a 50mm bkk.
Post by magoconnor on May 9, 2018 20:04:38 GMT -5
Yeah I thought so too, What do you think about the spark plug?
