shortman1166
Post by shortman1166 on May 9, 2018 11:57:44 GMT -5
My scooter seems to run best with .02" and .025" valve lash with stock motor. But I am about to install a 47mm BBK, Do I need to adjust the valve lash or should it be good to go with the same settings I am using on the 49cc? I am keeping the stock head as well if that makes a difference.
Post by scooterted on May 9, 2018 12:17:04 GMT -5
That should be ok. Expecially if its been working. You should recheck it when you reinstall everything of course.
Post by greginisn on May 9, 2018 22:09:05 GMT -5
There could easily be a couple of thousandths difference in cylinder height from the crankcase so you would be wise to check the valve gap when you finish the BBK install
Greg
