shortman1166
Post by shortman1166 on May 12, 2018 22:08:06 GMT -5
I just installed a 47mm bbk and its running on the same pilot jet as 49cc #32 and only went to an #80 main jet from a #78. Does that seem normal or am I missing something? It is still running the stock airbox and stock exhaust. I took the plug out and it looks like it may be a bit rich but I am going to run it for a day and check again before I change anything cause it seems to be running fine, it just seems odd with such a small change in jets.
