shortman1166
Post by shortman1166 on May 13, 2018 15:11:13 GMT -5
I took my scooter for a ride today with the new BBK installed and got the pilot dialed in perfectly I think(#32), I can idle down to about 800 RPM if I turn the idle down and it starts right up and comes off idle perfectly but I went for a ride and after about 2 miles it was surging at WOT then stalled. I got it back home and went from an 80 to an 85 main jet and haven't had time to go for a longer ride yet but it has a slight hesitation then recovers all the way to WOT if rolling open on the throttle from at about 1/4 that moving the jet needle doesn't seem to change. Is it a hint that my main is still to small or do I need to install a washer and raise the needle even more? I pulled the spark plug and it looks light brown, not white or black.
Post by pinkscoot on May 13, 2018 22:49:06 GMT -5
Tuning is a process that requires tuning the whole system one step at a time. each component works together at some point. get your Main jet tuned in and working well at WOT then the needle for 1/8th to a little over 1/2 and last the and last the pilot jet by way of the A/F needle. Do some research about carb tuning and you'll have an ahh hah moment and it will be clear to you. Start here and Brent makes it very clear.
Post by sjfishon on May 17, 2018 8:22:24 GMT -5
I had a simular problem.I found there was 2 o rings put on the needle,I took one off and it works perfect.it would not recover,and sometimes would kill,on a fast rev,hope this helps. Steve
shortman1166
Post by shortman1166 on May 21, 2018 15:42:32 GMT -5
Found my problem, the gas cap was not properly vented causing fuel starvation by creating a vacuum in the gas tank. Now it runs great with an 85 main and 30 pilot with a 47mm bbk installed and derestricted airbox.
Post by magoconnor on May 21, 2018 15:54:20 GMT -5
How did you fix it?
shortman1166
Post by shortman1166 on May 21, 2018 17:32:20 GMT -5
I just drilled a small hole in the gas cap. It already had one started but they didn't make it all the way through so I finished it. Just a small one 1/16 of an inch is all I needed not so big that gas would come spilling out, but enough to vent and the cap is under the seat so I don't have to worry about water.
Post by sjfishon on May 25, 2018 9:10:52 GMT -5
Can you show a picture on how you drilled the hole?? Steve
Post by sjfishon on May 25, 2018 9:14:06 GMT -5
I. See on mine there is a smallchannel,below the rubber gasket,but it seems to run around and just end...cans really see how it vents steve
Post by sjfishon on May 25, 2018 19:33:31 GMT -5
I have a dif cap,mine pops up and locks with the key.can't see how it vents.
shortman1166
Post by shortman1166 on May 25, 2018 22:16:06 GMT -5
Are you having issues with yours running? I was having all kinds of issues that I initially thought was a jet or valve problem and all it turned out to be was the cap and a 10 second fix. Some tanks have a second vent with a charcoal filter on them, I would check to see if yours has that.
Post by GrumpyUnk on May 28, 2018 11:58:48 GMT -5
shortman.. I think you had an incomplete bore and your drill finished what should have been done at the factory. You were correct to not get a 'direct' hole all the way through as I think you'd have problems with fuel splashing out and spreading, making your machine a potential Molotov cocktail.
The other style cap, with the flip-up cover and key lock, seem to have their vent on the underside of the cap, out near the edge where there is a slot cut. I assume the slot leads to an internal opening for air to pass into the tank as fuel is withdrawn. Could be mistaken. tom
