Post by pete130 on May 16, 2018 5:09:11 GMT -5
Having trouble getting kickstarter pinion gear to meet to engage properly can only get to work with washer remover should i just use thiner washer dont want to not use a washer at all, unless i have to have eletric starter but hi comp motor may not wind fast enough motor not finished pic 1 is with washer pic 2 with out and nut looks to sit were it should
Post by ThomasTPFL on May 16, 2018 9:06:08 GMT -5
I'd run it with no washer or a thinner washer, make sure that the nut isn't bottoming out on the splines of the crank though or you'll hate yourself next time you have to remove the variator.
Post by geoffh on May 16, 2018 15:10:02 GMT -5
I just run a stock yamaha so can.t help with your mods but a common problem is trapping the belt between the variator plates and then the crank nut won,t sit right ,just a thought.
geoff
