Post by magoconnor on May 22, 2018 22:41:53 GMT -5
Hello.
Im in a situation now, where I might need to go up in main jet. I running with a open cone filter, I've tried to cover it a little with tape, and it ran some what better.
So i tried to cover the whole filter in malossi red sponge, which made the mixture to rich and the bike lost speed.
Do you think if I went down in main jet would equal out the less air flow? Or will the filter be to restricted to supply my 72cc Bvh ?
The question really is, what will generate the most power? Cone filter with a bigger main jet? or cone filter wrapped with malossi red sponge and a smaller main jet?
Post by scootnewb on May 23, 2018 3:06:16 GMT -5
I would add a bigger jet if the new air filter makes it run lean instead of trying to restrict the air filter.
Post by Happypancake! on May 23, 2018 5:14:48 GMT -5
Post by magoconnor on May 23, 2018 17:10:28 GMT -5
You are right.. This post may be deleted.
