Post by illpoet on May 30, 2018 17:19:02 GMT -5
So i picked up an eton beamer 3 and she runs good after i adjusted the idle on the carb. I've been looking at 70cc kits since i first rode her but there are soo many! Could anyone recommend a decent kit? also is there a good jet/filter/exhaust combo to go with it? thanks!
Post by 190mech on May 30, 2018 20:10:28 GMT -5
They have a 10mm piston pin,,the oil pump is larger and will crash into the side of an aftermarket cylinder,so the cylinder must be notched to clear(or delete the pump..) A name brand kit with a matching head will be waaay better than a cheap junk cylinder...
Post by pinkscoot on May 30, 2018 20:29:48 GMT -5
I would suggest you follow some of the build threads here and make your own decision based on what's best for you. Definitely stay with a name brand, there are lots of no-name kits on Amazon and Ebay. That said if you want to just play and do it cheap try one of those and figure out what you want. There is nothing to say you only need to put one kit on. But remember you can only do one at a time.
Post by 90GTVert on May 31, 2018 7:35:45 GMT -5
Post by illpoet on May 31, 2018 10:46:58 GMT -5
They have a 10mm piston pin,,the oil pump is larger and will crash into the side of an aftermarket cylinder,so the cylinder must be notched to clear(or delete the pump..) i was thinking of deleting the pump anyway, back when i used to work on old mopeds i gained a serious mistrust of oil pumps, prefferring to just mix my gas myself so i know exactly what the mix is. This clinches my decision thank you.
Post by illpoet on May 31, 2018 10:48:21 GMT -5
thank you i will check this out. i combed the forums for eton beamer threads, i should have been looking for JOG references...
Post by 190mech on May 31, 2018 17:20:04 GMT -5
More Eton info;DC CDI(some are restricted),13.55 to 1 final drive ratio,long case "chinarelli",crappy small spline variator that limits roller travel,drive belts are shorter for the crappy variator(should run a 788)..
