Post by scootnewb on Jun 3, 2018 19:25:14 GMT -5
Hello,
I purchased a couple of jet kits in the past. Currently the 98 is slightly too small. The 100 was mislabeled or defective, I lost the 105 which was just a tad rich and there weren't any jets in between. I'm wondering if there's a kit with 99,100,101, etc etc
Thanks
Post by scootnewb on Jun 3, 2018 20:59:41 GMT -5
i guess they don't sell those.. even just as singles i could only find a 102 and a 108. ill just grab the 100, and 102
Post by scooterted on Jun 4, 2018 6:39:11 GMT -5
Post by GrumpyUnk on Jun 4, 2018 11:43:19 GMT -5
Post by scootnewb on Jun 4, 2018 13:01:47 GMT -5
Thanks. I have similar sets to those you mentioned but wondered if there were some that went up only 1 jet size between 99 and 110 because it seems like the sweet spot for me is located between 98 and 105. I'm probably going to order a 100, 102, and 105 cause I lost the 105 and the 100 i had seemed defective / mislabeled.
Post by scooterted on Jun 4, 2018 13:02:54 GMT -5
Those look like a good really affordable option. At that price i would still be skeptical of the actual size of the jet (as scootnewb has already experienced). But at that price you can buy a bunch.
Post by 90GTVert on Jun 5, 2018 14:50:43 GMT -5
I'd prefer to use a jet set or, if purchased individually, only jets from a big brand like the carb manufacturer or Polini or Stage6. Your 4T will be more forgiving, but I have killed an engine before because a "larger" jet was actually smaller in a kit that I pieced together. Went out and bought jet sets from one brand after that.
Post by scootnewb on Jun 12, 2018 22:42:38 GMT -5
Yikes.
I'm hoping the Hoca ones are ok. I received a 100 and 102 from them and have a 36 and 37 pilot on the way.
Post by scooterted on Jun 13, 2018 6:24:27 GMT -5
Ive been using a mix of chinese and hoca jets. Ive been running without problems. 4t are pretty forgiving. I would trust the hoca.
If youre still worried. when you settle on a jet. Do a plug chop to check for a safe ratio. Its what i do.
Post by 90GTVert on Jun 13, 2018 8:12:11 GMT -5
Yikes. I'm hoping the Hoca ones are ok. I received a 100 and 102 from them and have a 36 and 37 pilot on the way. That's probably fine. Just try to keep buying HOCA jets if you need more.
