Post by apelinkov on Jun 9, 2018 19:10:39 GMT -5
Hello again!! This forum has been really helpful so far with my questions so thank you!!
-Now, i installed led blinkers on my eton beamer 3 and of course they are hyper flashing. Does anyone know where the relay is located on the beamer 3 and whether or not I need a two or three prong relay to balance the blinkers out?
Post by 90GTVert on Jun 10, 2018 9:46:28 GMT -5
Not sure where it is on the beamer, but they're commonly either under the front fairing or the handlebar fairing.
Get a 3 wire. I've never had luck with the 2 prong units that claim to work with LEDs. The 3 wire relays add a ground and they've always worked for me. If you only have a 2 prong, it's easy enough to convert to 3 by just connecting the other wire to ground. Can be a nearby frame or harness ground.
