handyman
missing riding my scooter thanks to the winter here in the northeast.
Post by handyman on Jun 10, 2018 6:15:04 GMT -5
I just took my 49cc Tao Tao out from storing it in my basement hooked up the battery and checked all the fluids and after a few cranks, it started. I thought Ye-Ha!. I increased the throttle, and after about 20-sec it stalled, after trying to start it I got nothing, I checked the fuse and sure enough it was blown, not only was it blown it heated up so much it melted the casing that holds the fuse. I replaced it and it this time I was watching the fuse as it blew. I believe it is a broken wire grounding out on something. I did notice the gas gauge was working then it was not. I guess I will start there, But what weird is the fuse kept blowing when I increased the throttle. Does anyone have any advise where to start
Post by 90GTVert on Jun 10, 2018 7:03:31 GMT -5
Post by humanshield on Jun 10, 2018 10:24:43 GMT -5
I would open the front covers so all the wiring connections are exposed and disconnect the harnesses. Then disconnect the harnesses under the seat and towards the rear.
Put a new fuse in.
If it does not blow, start reconnecting the harnesses until it does. Then you've isolated the short to a handful of components. Then you can check each component or use a schematic and a VOM to find the short.
How long was it in storage?
Post by pinkscoot on Jun 10, 2018 13:19:00 GMT -5
Any mice droppings? Some varmit could have moved in and made lunch of your wires.
Post by humanshield on Jun 10, 2018 13:59:21 GMT -5
Around here, you leave it outside and human varmits will be your biggest concern
handyman
Post by handyman on Jun 23, 2018 6:12:04 GMT -5
When I unplug the rectifier the positive cable kept sparking, so I installed a new one and the problem was solved. Thanks for all the advise.
