Post by brombra on Jun 20, 2018 9:19:19 GMT -5
There are two washers in my variator. Does anyone know which one or both are the restrictng ones? Thank you.
Post by brombra on Jun 20, 2018 9:22:45 GMT -5
Another photo
Post by pinkscoot on Jun 20, 2018 9:42:28 GMT -5
The fatter one definitely is a restrictor washer, you can see how restrictive by how much of the variator isn't being used. The other one may be, the only way to know is if removing it doesn't let the nut go on properly. A picture of the variator installed would be helpful.
Post by brombra on Jun 20, 2018 10:03:16 GMT -5
The fatter one definitely is a restrictor washer, you can see how restrictive by how much of the variator isn't being used. The other one may be, the only way to know is if removing it doesn't let the nut go on properly. A picture of the variator installed would be helpful. I've put it back together now and I ended up removing the fatter washer and leaving the thinner one as I couldn't tell whether splines were sticking out past the kick start thing so I thought I'd better be safe than sorry. Here is a couple of pictures of the variator before disassembly.
Post by pinkscoot on Jun 20, 2018 10:09:31 GMT -5
Try it with the thinner washer in. You'll definitely see a gain. mark your variator and see how much belt travel you get now.
Post by brombra on Jun 20, 2018 10:20:50 GMT -5
Try it with the thinner washer in. You'll definitely see a gain. mark your variator and see how much belt travel you get now. Thank you for your help! I'll mark it in a bit and then go for a ride later, if there's still not full travel I'll take that thinner one out.
Post by pinkscoot on Jun 20, 2018 11:17:33 GMT -5
You may never get full travel but you should have better now.
Post by brombra on Jun 20, 2018 11:19:12 GMT -5
You may never get full travel but you should have better now. True. Anything to not be pinned at 30mph with the engine screaming will be nice!
