Post by KSR Moto on Jun 22, 2018 13:24:58 GMT -5
As you guys know there are heads with 64mm valves and with 69mm, now my question is do they need to be adjusted differently, bigger valve lash would make sense for 69mm since there is more metal in the valve that is going to expand
Post by 90GTVert on Jun 22, 2018 13:41:27 GMT -5
You can use the same setting for either.
