Post by KSR Moto on Jun 25, 2018 14:25:30 GMT -5
Could this exhaust valve be burnt?
Post by KSR Moto on Jun 25, 2018 14:30:23 GMT -5
This head however looks good to me, both valves black
Post by jackrides on Jun 25, 2018 17:26:46 GMT -5
With the valves closed, pour a thin liquid (if flammable, do it outside) into the port. No leakage thru valve, it's ok.
Post by jackrides on Jun 25, 2018 17:33:09 GMT -5
Valve spring compressors are under $20. on Amazon
Post by scooterted on Jun 25, 2018 17:48:41 GMT -5
And you can rent compressors at most auto part stores.
Post by GrumpyUnk on Jun 26, 2018 13:00:18 GMT -5
If you bap the valve spring retainer washer(?) with a hammer, many times you'll have projectile parts flow. The keeper(s) may decide to take flight, and then you can remove the keeper & spring, and slide the valve out of the head. Problem is locating the keeper that took flight. Surprised the heck out of me when all I wanted to do was to make sure the parts were 'broken free' and could be separated. I planned to use my thumbs to depress the spring, and a magnet to remove the keepers. No need, they flew... So, if they are not locked together by time & lube that has turned to glue, you can remove the parts if your thumbs are strong enough and you have something to pick the keeper from the washer cone. Installation is the reverse, no tool necessary. You may want to wear gloves if the edges of your machined surfaces are sharp and cutting.(or round them off...) tom
