Post by 308reticle on Jun 28, 2018 23:07:17 GMT -5
Hey folks,
First and foremost, I have been lurking around as a guest for a week or so and finally decided to stop being a leech and join up already! From what I can tell, you all look to be a good group of helpful forum members.
So back to task at hand. Backstory: I scored a free 2009 VIP Future Champion 49cc gy6 that was laying around my friends farm accross the street from me. He got it for free so I dont know much about its past. From what I can tell, its been laid down more than once. And Im assuming it was someones DUI mobile. Maintenance looks to be slim to none. So after telling myself over and over not to go crazy and spend too much money on this haggard old scoot, I decided to keep it simple. I ordered a cheap "performance" kit from J and J Powersports. It came with "Precision Jetted Super-flow carb, High Performance Coil & CDI for increased spark and engine timing, and
Super Flow Air Filter." Their words not mine. Also got a belt and 7 gram rollers for free. When the parts showed up it was clear to me that i just got suckered. The parts received weren't the parts in the picture. However, It did wake the little 49cc motor up a bit.
So after getting everything working well, it was time to tackle the CVT. Now CVTs and I have a love hate relationship. Im familiar with them due to modding a few Polaris RZRs over the past few years. Currently still battling to get my clutching tuned right on my RZR XP turbo. So while I understand the concept, im man enough to admit that my patience with CVT systems are lacking and I usually end up bruised beaten and defeated.
I pull the cover only to find what i expected to find. a mess. after inspection i found that i need a new primary (i believe its called a variator in the scooter world?) the sheaves look like they chewed up a bolt or something at one point. But for now all i have is a new cheapo secondary to put on and some new weights and belt.
Heres where it gets interesting. Comparing gates belt I pulled off and new knock off belt I got for free, it was clear the new belt was wider. Witch I expected because the old gates belt was clearly worn hard. (should have seen the amount of belt dust in case) so first thing I did was put on new belt and run it. with new belt it would not run out well. it just sat down around 5k rpm and didnt really want to get up and go. so i messed with weights and got a little more acceleration but still lacking in rpm range (shooting for around 8k rpm) so finally I put in new secondary springs. (blue).
after changing around weights and springs I still had the same problem. lacking hard in top speed and barely catching 6500rpm downhill. So finally I ended up with this: New (cheap) secondary with blue springs in it, factory weights in primary, and old worn gates belt. For whatever reason that old belt gets it running the best. great acceleration. still a little lacking in rpm but during acceleration i see about 7k rpm. but once the belt runs out my revs will drop to about 6k then begin to climb up to 7500 on flats and 8 to 8500 on downhill.
Im not sure where to go next. Im going to order a new variator because mine is pretty beat but why in the world does my old worn out belt make this thing go and the new belt leaves me feeling like it would be faster to get off and walk?
