Post by hamodyjog on Jul 9, 2018 22:04:55 GMT -5
Hi so i had this issue with my yamaha jog 50 cc 2 stroke where it would almost die and it loses all power, and at that time it had no air filter, so today i bought a new air box or filter whatever you wanna call it and i also cleaned out the carburetor with carb clean, the bike didn't wanna start at first but it started, then when i wanna go somewhere it would just sound like it's gonna die all the way from. Idle to 3/4 throttle, and sounds very loud and vibrates like hell, it has an exhaust with no restrictions maybe that could be part of the problem, i really don't know what to do other than play around with the idle speed and mixture screws please if you know anything about this issue tell me about it
Post by 90GTVert on Jul 10, 2018 6:11:01 GMT -5
Did you make sure the jets were clear when you cleaned the carb? 49ccscoot.proboards.com/thread/363/carburetor-cleaningIs it the same symptom now as before the air filter? You say airbox or air filter, but which is it? Is it a stock replacement (big black box with a hose to attach to the carb) or an aftermarket pod filter (just a filter that clamps to the carb)? Here's a lot of carb tuning info that wouldn't be bad to read up on. www.49ccscoot.com/faq/carbtune.html
Post by hamodyjog on Jul 11, 2018 8:43:57 GMT -5
Did you make sure the jets were clear when you cleaned the carb? 49ccscoot.proboards.com/thread/363/carburetor-cleaningIs it the same symptom now as before the air filter? You say airbox or air filter, but which is it? Is it a stock replacement (big black box with a hose to attach to the carb) or an aftermarket pod filter (just a filter that clamps to the carb)? Here's a lot of carb tuning info that wouldn't be bad to read up on. www.49ccscoot.com/faq/carbtune.html i did make sure that the jets were clear, i cleaned every hole in the carburetor, and i got an air box stock one , and before i put the air box it did that but not as severe when i put the air box, I'm planning to open the carb and change the needle position and make it richer and see if it helps or not, if it makes it worse I'll lean it out
