Post by Danielle Belle on Jul 15, 2018 22:06:27 GMT -5
I was driving my scooter when I hit a bump and now my Center kickstand is dragging anyone know what might have happened
Post by scootnewb on Jul 15, 2018 22:23:01 GMT -5
So the center stand, it no longer stays all the way up? Can you take some photos? Is the spring still on? Is anything bent?
Post by Danielle Belle on Jul 15, 2018 22:30:27 GMT -5
Yeah it just won't stay up I think this spring or something fell off but not sure
Post by Danielle Belle on Jul 15, 2018 23:02:56 GMT -5
I went ahead and just took off the centwr stand for now. Is it ok to drive the scootwr without the centwr stand on?
Post by scootnewb on Jul 15, 2018 23:06:31 GMT -5
Yes.
Post by Danielle Belle on Jul 15, 2018 23:49:58 GMT -5
Thanks
Post by 90GTVert on Jul 17, 2018 13:39:49 GMT -5
Just be a little more careful parking using the side stand. It'll be more prone to sinking in on soft surfaces and not quite as secure if it's windy or anyone messes with it. Usually the center stand has 2 springs. Often a small spring inside of a larger spring. If either of those were missing that could cause it. If the clip wasn't keeping the pin on place that could do it. Could be wear or damage to the stand or the case where it pins on. Could be that the post that the springs attach to got bent. Here's a pic of a working stand, just in case it's of any use. photo upload and link
Post by pinkscoot on Jul 20, 2018 20:30:23 GMT -5
Be careful leaving the scooter running unattended on the side stand. If the wheel spins at idle it will drive it off the stand. For the problem of the stand and sinking just carry a thin block of plywood to set under it or buy a stand puck. If it was me I would fix the stand to save those headaches. Brent has a great tutorial on how to put the springs back on.
