Ac cdi?
Jul 18, 2018 23:47:10 GMT -5
via mobile
Post by jdl357 on Jul 18, 2018 23:47:10 GMT -5
Ok, my cdi is big, and has only 1 wire in the 2 wire slot like a DC cdi. But the engine runs without the battery connected? So it has to be AC cdi- right???
Ac cdi?
Jul 19, 2018 1:26:12 GMT -5
Post by FrankenMech on Jul 19, 2018 1:26:12 GMT -5
Did it start without the battery connected?
Ac cdi?
Jul 19, 2018 3:06:56 GMT -5
via mobile
Post by jdl357 on Jul 19, 2018 3:06:56 GMT -5
It won't kick start with the battery disconnected.
Ac cdi?
Jul 19, 2018 3:36:59 GMT -5
Post by FrankenMech on Jul 19, 2018 3:36:59 GMT -5
then it is probably a dc cdi. an ac cdi can be kick started without a battery.
a running engine produces dc even without a battery.
Ac cdi?
Jul 19, 2018 3:47:53 GMT -5
via mobile
Post by jdl357 on Jul 19, 2018 3:47:53 GMT -5
Ok, thanks for the info. I guess the two I've tried are both ac cdi's. With them hooked up it'll crank over a few times then blow the fuse by the battery. I'll look for a DC one and see how it goes, thanks again!
Ac cdi?
Jul 20, 2018 5:47:52 GMT -5
Post by cagiva4ever on Jul 20, 2018 5:47:52 GMT -5
most DC-cdi's have 4-pin's on connector block. also the size varies, so "big size" isnt always absolute sign of dc-cdi..... also, you can see if a strong Neondynom/earth magnet gets stuck on it. usually on the bottom RH-corner, from component side of the PCB. most china scooter DC-cdi's have a "transformer" on the pcb, it has iron core, hence strong magnet will get stuck onto it. this magnet identification isnt always absolute Trick, as some dc-cdi's have some other component construction Layout.... like a "diode bridge"... see how many Signs you can identify. and also check your Vehicle parts list/W.S.M and owners manual. cdi spec is absolute mentioned on some of those.
i have all of these parts my self, i have approx 40+ diff cdi's for China scooters etc china vehicles. and also european scooters/mopeds.
Post by FrankenMech on Jul 20, 2018 20:31:44 GMT -5
One can always trace out the wiring to the CDI and see if it connects to the battery etc.
