Post by Deleted on Jul 21, 2018 12:52:10 GMT -5
I saw this video fitting minarelli stroker crank to honda engine (af49) years ago. Been searching this video and if this is endeed possible. There's a lot of meet to fit stroker. Can't seem to find crankshaft bearings measuring 20x56x14 mm?
Post by harleyracer59 on Jul 24, 2018 2:06:41 GMT -5
I gotta ask. what are the differences between an af49 and other dios af16-18, af28. thank you
Post by Deleted on Jul 28, 2018 15:22:26 GMT -5
I think difference being in crankshaft bearings, oil seals and 2t oil distribution is in variator side. Also stud spacing is the same with minarelli engines. Honda af49 have the same stud spacing that chinarelli does (measured as the diagonal, from top left stud to bottom right stud, as 72mm).
