Post by friday1 on Jul 21, 2018 21:59:49 GMT -5
New to all the scooter abbreviations and acronyms. I have a 2002 SR50 Aprilia. Who made this motor? How can I tell if I have restricted ignition? Thanks in advance, Friday
Post by ThomasTPFL on Jul 21, 2018 22:16:46 GMT -5
Isn't '02 Morini? Or was it still Minarelli?
Is it a fuel injected model?
Post by Lucass2T on Jul 22, 2018 12:21:03 GMT -5
Take a pic of the cvt cover. It can be minarelli, morini and even piaggio!
Post by friday1 on Jul 22, 2018 12:56:52 GMT -5
Isn't '02 Morini? Or was it still Minarelli? Is it a fuel injected model? No it has a small carb.
Post by friday1 on Jul 22, 2018 12:58:31 GMT -5
Take a pic of the cvt cover. It can be minarelli, morini and even piaggio!Help me out here a little. What is the CVT cover? Is that the constantly variable transmission?
Post by Lucass2T on Jul 22, 2018 13:11:50 GMT -5
Take a pic of the cvt cover. It can be minarelli, morini and even piaggio!Help me out here a little. What is the CVT cover? Is that the constantly variable transmission? Correct
Post by friday1 on Jul 22, 2018 16:18:20 GMT -5
CVT 2002 SR50 Aprilia Replica Thanks for the help.
Post by Lucass2T on Jul 23, 2018 2:52:33 GMT -5
Thats a minarelli engine. Same motor as the aerox. They're only restricted with a ring in the variator and maybe a funnel in the exhaust header. Remove both and gain about 10-15mph.
Post by friday1 on Jul 23, 2018 16:15:44 GMT -5
Thats a minarelli engine. Same motor as the aerox. They're only restricted with a ring in the variator and maybe a funnel in the exhaust header. Remove both and gain about 10-15mph.Thanks Lucass2T, how do I tell if the ignition is restricted?
Post by Lucass2T on Jul 24, 2018 1:24:41 GMT -5
Thats a minarelli engine. Same motor as the aerox. They're only restricted with a ring in the variator and maybe a funnel in the exhaust header. Remove both and gain about 10-15mph.Thanks Lucass2T, how do I tell if the ignition is restricted? It isnt. Only the older smaller minarelli based scoots are restricted like my Axis. Your SR isnt. You can check by looking at the wires coming from the cdi. If it was restricted your cdi should have a green/white wire going to the stator. Unplug the connector, leave the wire from the cdi but put the end coming from the stator to ground.
Post by friday1 on Jul 24, 2018 15:43:39 GMT -5
Thanks Lucass.
