Post by GrumpyUnk on Jul 23, 2018 12:26:33 GMT -5
I installed a 44mm cylinder, piston and rings to a Taotao that had a questionable 47mm BBK previously installed.
Previously, the starter would crank the engine over enough to get it to start, but was very 'peaky' in that it would crank very slowly on the compression stroke. I think.
Anyway, after the 63cc set was installed, it cranked very slowly. I figured the brushes may be gummy, the bearings/bushings dry, and the starter in general need of a 'cleanup and lube'.
Wrong.
Both permanent magnets came out of the housing along with the armature, clinging tightly to the metal of the armature. Oops.
I separated all three parts, keeping them in the same relationship out of fear of installing things backwards(no markings on the magnet, so I made one to mark 'this end out'. No way to know which magnet was attached where as they had rotated upon removal.
How it ever worked I have no idea.
I cleaned up the magnets, and the case, mixed some epoxy, and glued them back in place successfully. I thought.
Re-assembled, and installed. Bzzzz. Bzzzz.
Rats, the Bendix & planetary fell out of place. Fiddle fiddle.
Try again. Bzzzzzz Bzzzz.
The armature rotates in the wrong direction.
What do I do to make it rotate in the correct direction?
Flipping the Red and Black seemed reasonable, but, the body of the starter is 'ground'. Connecting the red wire to ground does not seem like a good idea.
Given that the magnets are epoxied in place, would removal and swapping one for the other do anything? It does not make sense mentally to just move the N 180 along with moving the S similarly. They are still right there... of course the armature connects 180 off from the current setting...
I *think* removing the magnets and moving them might work, but brain not working...
Any ideas?
tom
Wrong.
Any ideas?
tom
