Post by perpendicular on Jul 26, 2018 10:05:20 GMT -5
I have a 2011 Vino Classic 4 stroke and am at a loss on what to do. I cannot find a stock carb for it anywhere, national backorder, etc. So I am trying to figure out what carb I can buy that will fit on the bike. I am ok with going a bit bigger or staying stock but other than that I have no idea what will fit, what will work correctly and what it going to be more of a pain to keep running.
Can anyone share some threads about carb's that will work on my scoot and what is a good choice?
Thank you!
Post by tortoise2 on Jul 26, 2018 11:14:59 GMT -5
What specifically is deficient with the present carb? Parts diagram. Service manual pdf . . reference chapter 7. Original carb has a throttle position sensor . . most 139QMB engine carbs do not, and the enricher electrical connector would probably be different. Even scooterpartsco.com does NOT have a compatible carb listed.
Post by perpendicular on Jul 26, 2018 11:40:13 GMT -5
I bought the bike as it has not been started in a very long time. I attempted to clean it up but still can't get it running so decided to start with replacing it.
Post by fugaziiv on Jul 26, 2018 12:12:10 GMT -5
This is a strangely particular carb to this bike and doesn't seem to be really duplicated in the aftermarket. It doesn't even cross to any other 50cc Yamaha models that I can find. If you aren't able to clean and rebuild, your best bet is to suck it up and buy OEM unless you want to get into modification.
Matt
Post by tortoise2 on Jul 26, 2018 12:20:15 GMT -5
Unclear what fuel-spark-compression troubleshooting efforts you have made? Will the engine try to run after removing the air filter and spraying in a shot of starting fluid?
Post by tiny on Jul 26, 2018 17:17:11 GMT -5
Not much crosses over on the Vino. Other then the engine and CVT everything on the Vino is unique to the Vino. I was lookin into a new carb for the wifes Vino but it would require either changing or modding the throttle cable for any aftermarket carb. Good luck mate.
Post by perpendicular on Jul 30, 2018 6:51:07 GMT -5
Thanks for all the help! I don't mind going factory but they are nationally back-ordered. I have been trying for 3 weeks to get one I will keep looking though. As for what what spark-compression troubleshooting. It has perfect compression and spark, checked those out. The bike literally sat for years. since last started. Yes, starting fluid will make it run a bit but very hesitant to continue.
Post by tortoise2 on Jul 30, 2018 10:47:03 GMT -5
It has perfect compression and spark, checked those out. The bike literally sat for years. since last started. Yes, starting fluid will make it run a bit but very hesitant to continue. Have you NOT cleaned the jets in the present carb?
Post by perpendicular on Jul 30, 2018 14:47:14 GMT -5
I believe I have, yes.
