ratdog
Post by ratdog on Jul 28, 2018 7:15:59 GMT -5
OK, to make a long story shorter ( in case you haven’t read my other posts). I have an ice bear falcon moped that my stupid nephew ripped the wiring out of in an attempt to “hot wire” the bike. Most of the damage I have traced, except for one ground wire. There is a long wire attached to the mounting bolt on the ignition switch. But I have no idea what it was attached to on the other end. I’m hopping that someone out there might know where the other end of this wire should go
Post by GrumpyUnk on Jul 28, 2018 8:34:43 GMT -5
I do not know for sure, but would suspect it should go the the rest of the 'frame'. The handlebar & fork are connected to the frame though the ball bearings of the fork, which is not a reliable connecting means. Running power through greasy ball bearings is somewhat tentative. tom
Post by humanshield on Jul 28, 2018 9:20:47 GMT -5
Yep, if it's connected to a mounting bolt on the ignition switch, rest assured it's a ground wire.
What's on the other end and does it look home made or like it came with the scooter?
Some ignition switches had a mount welded right to the main frame while other have the switch on the triple tree. If yours is mounted to the frame with a direct ground, it probably doesn;t need another ground. That gound could be for the harness.
Again, what's on the other end and does it look like it came with the scooter or was home made?
