My_Little_Kymco
After her little facelift, following "trouble with a white van!"
Post by My_Little_Kymco on Aug 3, 2018 9:18:05 GMT -5
Hi mt little kymco is playing up. I think is a fuel issue but need some suggestions. It ticks over perfect, but when i open throttle it will either rev perfectly or will lose revs randomly.
I recently replaced the carb as old one was clogged and the jets was trashed ftom earlier tinkering.
Any suggestions gents?
Post by AtariGuy on Aug 3, 2018 11:25:52 GMT -5
Could be spark. Check that your spark plug cap is fully connected and the ground cable is fully secured at the coil (follow the spark plug cable back to the coil to find it). Also be sure your stator, cdi, and coil connectors are solidly in place. Perhaps add some dielectric grease while you're checking on them to waterproof them.
