Post by lostforawhile on Aug 8, 2018 20:40:04 GMT -5
This is almost finished,my new rear fender was nearly hitting my stock air box, so something new was needed, this is built around a briggs 795066 cartridge and pre filter. Multiple pictures imgur.com/a/HIXgIUF
Post by oldgeek on Aug 8, 2018 21:13:09 GMT -5
Nice!
I used the same filter directly on my 19mm dell carb inlet, but I had a hard time keeping it attached.
PirateLabs
Post by PirateLabs on Aug 8, 2018 22:02:40 GMT -5
Nice job and it looks good. Did you cap off or block that elbow on the intake hose that used to go to your airbox? In your last photo, it appears to be open to the air...unless you filled it with silicone or something we can't see in that shot.
Bill
Post by lostforawhile on Aug 8, 2018 22:35:52 GMT -5
Do you mean the fitting on the hose? I've got to tie the breather hose into it,Theres a lot of stuff not hooked up right now,
Post by lostforawhile on Aug 8, 2018 22:37:52 GMT -5
Nice! I used the same filter directly on my 19mm dell carb inlet, but I had a hard time keeping it attached. a standard pvc end will fit tight enough into that,where you need to twist it to pull it back out
Post by lostforawhile on Aug 8, 2018 22:59:59 GMT -5
Nice job and it looks good. Did you cap off or block that elbow on the intake hose that used to go to your airbox? In your last photo, it appears to be open to the air...unless you filled it with silicone or something we can't see in that shot. Bill this is the fitting, 1/8 npt will screw right into it. I need to get a barbed fitting for the line imgur.com/a/XPuxtQ4
PirateLabs
Post by PirateLabs on Aug 9, 2018 9:13:43 GMT -5
Nice job and it looks good. Did you cap off or block that elbow on the intake hose that used to go to your airbox? In your last photo, it appears to be open to the air...unless you filled it with silicone or something we can't see in that shot. Bill this is the fitting, 1/8 npt will screw right into it. I need to get a barbed fitting for the line imgur.com/a/XPuxtQ4Excellent. I just thought you might have forgotten about it but, obviously, you have not. Good work. Bill
