Post by bajasc50 on Aug 18, 2018 21:00:46 GMT -5
Hello forum! I have a baja sc50 with a QJ139QMB-3 that uses minarelli 1E40QMB transmission parts and has a very unique belt size.
The belt that came with the bike is 836-17-30 which is almost impossible to find a quality replacement for.. however Gates makes a Powerlink Premium 835-17-28 which is really close in size.
What do you all think? Is that belt close enough in your opinions? I'm particularly not sure about the 2° difference in the last number.. if it's a steeper belt how will that change things?
Post by AtariGuy on Aug 22, 2018 1:57:38 GMT -5
The vari would still accept it and belts that are close (within 2 degrees) generally conform to the variator plates pretty quickly. If you have the ability, try measuring the angle of the fixed drive face of your variator, it'll probably show 14.5°
