Post by gouvis on Aug 24, 2018 12:51:43 GMT -5
I just received my glixal 50mm cylinder piston kit and i weighed the piston with the piston rings. I used two different scales and as it seems it weighs 74g. 90GTVert got 93g from his scale for the 50mm piston with the rings. Glixal's seems pretty low weighed to me. I will check with a third scale too. Is there anybody that weighs the pistons before uses them? It would be nice to know the weight difference between different brands.
Post by jackrides on Aug 24, 2018 13:06:39 GMT -5
Shouldn't wrist pin be added in?
Post by gouvis on Aug 24, 2018 13:51:28 GMT -5
Yes finally with the piston pin it's almost the same as 90GTVert.
ratdog
Post by ratdog on Aug 24, 2018 14:25:38 GMT -5
You should weigh the stock piston and pin too, just for comparison.
