Post by joebob on Aug 30, 2018 20:07:05 GMT -5
2013 taotao 150cc 4 stroke ... as per title, the idle moves up and down within a limited range all on it's own. bogs down a bit when giving it throttle and on full throttle it doesn't quite rev freely. carb is squeaky clean inside and out. air filter is new with less than 10 miles on it. cannot find a vacuum leak anywhere. fuel is fresh. enricher extends as it warms up but the engine does not go into a fast idle on start-up; just the opposite, it idles slowly when cold, slowly picks up speed as it warms up, then goes into its up/down idle routine. as a last resort i took the brass cover off the idle mixture screw and removed the screw. it is clean and it's bore looks clean but i didnt spray any carb cleaner in there. re-installed carb, then tried adjusting the idle MIXTURE screw in and out. no difference ... in fact, the engine still idled even though i bottomed the screw out; can that be right ? also, even though i cleaned and cleaned, i am not 100% sure that the lengthwise bore of the idle JET screw is ok. it's hard to tell because the bore is so tiny, and my eyes are getting old, but there seems to be a burr inside there. could be an optical illusion though. a strand of wire from a wire brush will go through, but nothing larger. i can remove carb and try cleaning the bore of the idle MIXTURE screw with carb cleaner and compressed air, which i should have done 1st time around, but beyond that i am running out of ideas. could go the new carb route i suppose but this scooter only has 3400km (2500mi.) on it !
Post by Happypancake! on Aug 30, 2018 20:18:58 GMT -5
Have you sprayed carb cleaner between motor and carb while running to find possible vacuum leak?
Post by joebob on Aug 30, 2018 20:44:54 GMT -5
no, but i used propane.
Post by Happypancake! on Aug 30, 2018 20:54:17 GMT -5
Pic of the crack which caused me similar issues.
Post by joebob on Aug 30, 2018 21:00:00 GMT -5
i dont recognize that part, pancake.
Post by Happypancake! on Aug 31, 2018 5:04:09 GMT -5
Is for a Honda GET motor. Carb intake. Not sure if your motor has something similar
Post by joebob on Aug 31, 2018 9:04:24 GMT -5
i figured that's what it was, but didn't want to assume. mine looks much different and is 100% plastic. i did check it for cracks, there are none. also the gasket is good but i applied some goo just to be sure. i read here somewhere that there may be a fuel filter inside the tank that is clogged, so will check for good fuel flow, hopefully today. meanwhile any suggestions are greatly appreciated.
ratdog
Post by ratdog on Aug 31, 2018 16:56:45 GMT -5
If adjusting the fuel air screw has no effect in idle, I would suggest that you have the idle speed set too high by the throttle stop. You have to adjust the throttle stop screw until it’s at the slowest RPM the bike will still run at, before stalling. Then adjust the mixture screw. You will find is has very little effect, but you want the fastest idle you can get with just that screw. Then set the idle with the throttle stop screw to get a comfortable idle.
Have yo tried unplugging the electric choke to see if it is effecting your idle when warm? I would start it and warm it up until you get the problem then unplug the electric choke
Post by joebob on Aug 31, 2018 18:45:41 GMT -5
hi, ratdog ... thanks for the info re: setting idle mixture screw. also, unplugging the enricher when warm is a good suggestion. sadly, i have screwed myself ... i lost the rubber seal that goes on the idle mixture screw so i am just going to order a rebuild kit. sigh ... another 4 weeks or more waiting for a part from china. there is only 1 place that i know of in my area (vancouver) that has even heard of taotao or gy6 and they don't stock carb kits... but they will be happy to sell me an entire carb for $129.95 canadian plus taxes. i will trim my pubes with a chainsaw before i will drop that kind of money on a taotao.
Post by walleye1963 on Aug 31, 2018 20:12:04 GMT -5
SOUNDS LIKE U MIGHT HAVE TO GO TO A BIGGER JET.IT SOUNDS LIKE ITS NO GETTING THE FUEL IT NEEDS.MY 150 DID THAT WENT TO A BIGGER JET PROBLEM SOLVED.
Post by joebob on Aug 31, 2018 20:51:46 GMT -5
hi, walleye. because i lost a small part of the idle mixture screw i am going to have to order a complete carb kit, so i guess i will use whatever size comes with the kit and see what happens. if that doesnt work then i will order an assortment of idle jets. project taotao resurrection now on hold while the slow boat makes its way over from china.
ratdog
Post by ratdog on Sept 1, 2018 9:16:13 GMT -5
Joe Bob, I know they have Amazon in Canada! You could get a whole new carb off Amazon under $30. Ok, I’m guessing at the price but I know what they are in USD and the discount rate isn’t THAT much. ( I live 3 miles from Canada. I take my bicycle rides along the river and look at Canada almost every day!)
Post by joebob on Sept 1, 2018 10:09:49 GMT -5
i will check that out, ratdog, thanks .
