Post by jeff84 on Sept 3, 2018 0:30:52 GMT -5
on the models that use valve shims. does anyone know what diameter shims are used?
Post by pinkscoot on Sept 3, 2018 14:10:44 GMT -5
I was even in there changing the cam and forgot to measure them. I have searched for the dimension all over the inter webs and found nothing but a guess and was waiting until my first valve adjustment to find out. Please share when you do.
Post by jeff84 on Sept 3, 2018 14:40:59 GMT -5
I found some on ebay uk that are advertised as fitting honda, Yamaha, piaggio scooters. they are 7.48mm, which if correct is a good thing because I already have some of those for my ruckus
Post by jeff84 on Sept 8, 2018 14:49:36 GMT -5
7.48mm is in fact the correct shims to use. now im going to have to order some as the range of thicknesses I have for the honda are no where near what I need for this piggy.
Post by pinkscoot on Sept 8, 2018 15:41:22 GMT -5
Thank you for the information. Being the same as the Ruckus might make them available from the Honda dealer.
