Post by Danielle Belle on Sept 4, 2018 18:15:11 GMT -5
What is the normal tire pressure for a 50cc scooter.
Post by gsx600racer on Sept 4, 2018 18:28:26 GMT -5
Year/make/model of your scooter would be helpful. Usually scooters will have a identification plate/sticker under the seat or on a panel with that information. Owners manual will have this info too.
Every scooter manufacturer has different tire pressure recommendations.
Post by Danielle Belle on Sept 4, 2018 19:57:50 GMT -5
Ah ok thanks. I found it. I'm such a goof lol
Post by scooterpimp on Sept 4, 2018 20:05:21 GMT -5
Tire pressure is also marked on sidewall of tire. Imo this is the best place to get tire pressure specs (manufacturer specs) p.s. your not a goof.
Post by GrumpyUnk on Sept 5, 2018 10:39:51 GMT -5
The tire pressure listed on the sidewall of most tires is the MAXIMUM pressure allowed to be used. Most makers do not suggest running at the maximum. More in the mid-to-high 20's of psi. I think around 26psi would be good. BUT, check with the maker as the numbers seem to be all over the map. tom
wahlman
Post by wahlman on Sept 6, 2018 20:41:14 GMT -5
I like to fill to 5 psi less than the maximum. Do that on my car tires also
