Post by Sir Scoots-A-Lot on Sept 9, 2018 8:05:50 GMT -5
I recently bought a new variator for my 50cc 4t. it has 5gram roller weights, I am currently using a 729 17.7 30 belt and Im fairly happy with speed at about 25mph on steep long uphills and 37-40 mph on long flat stretches with favorable or no wind. my variator kit came with what looks to be a fairly standard length drive boss that is within 1 mm of my stock boss.
I noticed that my old variator kit seemed to always get to 40mph on flat ground with no windwhereas the new kit usually only gets to 37-38 mph unless a good tailwind is present then it might hit 40mph. so I looked at the drive faces on the stock and new variators, which seem to be the same circumference, and the stock setup showed belt wear on the drive face at least few mm closer to the outside-- meaning my stock setup was achieving a bit of a higher gear, maybe because of slightly different roller weights or weight of the variator itself or maybe my new drive belt that claims to be the same size is slightly different.
My idea to achieve a higher gear on the new setup is to shave a couple mm off the drive boss, then test it, then maybe shave off more or not until im happy depending on the results.
My second idea is to install a 743 20 30 belt to get an extra half inch in belt circumference, a wider belt and hopefully achieve a higher gear. I got this idea when installing the new variator and belt I made sure the clutch was all the way open so the drive belt only had to go around the smallest part of the clutch, in the front I tried to see how far to the outside of the variator I could strecth the drive belt by hand and it seemed a bit short of getting all the way to the outside of the drive face although maybe the engine can strecth the belt better than my hands. then I tightened on my variator and noticed the variator is at least a couple mm short of grabbing the belt with the engine off and the belt around the smallest (inside) part of the variator.
so what do you all think? is it a good idea to get the half inch longer and 2.4mm wider drive belt and shorten my drive boss in increments? (my goal is to achieve a slightly higher gear and therefore a higher top speed -- assuming the engine rpm will stay the same) or will the slightly longer belt run the risk of jumping off? on that last note I did notice some wear on the outside of my drive belt where the belt must be hitting the cvt cover right where the two halves of the cover come together and im not exactly sure why that is happening if my belt isnt even hotting the very outside of the variator drive face?--my only guess to that outside belt wear is maybe my contra spring is so light that the clutch switches to high gear ( smaller clutch circumference for belt to go around) before the light variator weights open the variator so that the variator is still in low gear while the clutch is in high gear meaning the front and back pulleys are both short at the same time causing belt slack temporarily.
one last crazy idea to increase gear ratio is to get wider rollers for my 139qmb. stock rollers size is 16mm wide (diameter) x 13mm height (height from top to bottom of cylinder when standing on end)... so I found some other size rollers like 20mmx 15 mm but in higher weights than I want. my crazy idea is to machine it down to 20x13 so it will still fit in my variator but I am hoping it will push open the variator more with the same amount of engine effort and therefor possibly achieve a hogher gear. do you all think this is a good idea? will it work? or crazy idea that will break stuff??!!
any input is greatly appreciated because I know the cvt confuses me a little altough I would like to think I grasp the concepts individually, I know I get my thinking messed up at times at the very least when taking into consideration all the moving parts at different rpms and also changing the parts to different ones and how each little change has a big effect on the overall scoot performance
