Post by KSR Moto on Sept 11, 2018 7:55:31 GMT -5
Is this hole near the timing chain normal or is it damaged engine block?
Post by Deleted on Sept 11, 2018 8:05:26 GMT -5
Don't lose your hair over it! It's looks normal gy6 4t case.
Post by KSR Moto on Sept 11, 2018 8:45:40 GMT -5
Don't lose your hair over it! It's looks normal gy6 4t case. Thank you!😉
Post by GrumpyUnk on Sept 14, 2018 11:00:36 GMT -5
Unless it allows the oil to fall out, it is not going to cause problems. The oil fed to the cam, bearings and rocker arms has to get back to the sump somehow, and I expect it flows down the front of the chain aperature in the cylinder, and then through the opening you point out. If not, it surely must be real close. tom
