Post by paydem on Sept 13, 2018 4:42:53 GMT -5
After installing a no-name 70cc BBK for my Minarelli Horizontal 2 stroke engine and putting around 75 miles on it, the compression dropped a bit.
When the engine is cold, the compression is really good - when it warms up, the compression slightly drops. Still starts first kick, doesn't matter it's cold or hot. I don't have a compression tester to test how much it kicks in.
I'm interested if any of you had similar experiences. Should the engine drop some compression when it warms up?
Post by mantas on Sept 13, 2018 8:05:28 GMT -5
Same here, when cold it speeds up and goes really well, when its warm the scooter is speeding up much weakier and longer.
Post by mantas on Sept 13, 2018 8:06:22 GMT -5
Same here, when cold it speeds up and goes really well, when its warm the scooter is speeding up much weakier and longer. I have 3000 kilometers on it though
Post by 90GTVert on Sept 13, 2018 9:56:09 GMT -5
Compression should increase when warm, but shouldn't be much of a spread between cold or hot. It would be helpful to check this with a compression tester though. If you only notice because of the kick, you may be feeling something else.
