Post by magoconnor on Sept 17, 2018 15:32:04 GMT -5
Hello.
I normally dont mix weight, I usually run with six identical. Quick question, how much difference in terms of weight is safe to use?
Like say if I wanna use 3 x 5.5 and 3 x 6.7 gr. rollers would this be safe? I dont wanna cause excessive wear on the crank.
Cheers Mag.
Post by gsx600racer on Sept 17, 2018 15:41:51 GMT -5
I wouldn't go more than a gram of difference, but thats me. I'm sure others will say otherwise.
I think if there is a huge weight difference, the heavier rollers will wear out first seeing they would be the first to move before the lighter ones.
I also would only do this for tuning purposes and once you have it dialed in with mixed rollers, get the same weight for all 6 rollers.
Post by edwardtennant on Sept 20, 2018 8:19:41 GMT -5
Yea you can do, just make sure the weights are opposite each other, so for example it would be like this
5G,6G,5G,6G,5G,6G
