Post by KSR Moto on Sept 27, 2018 2:25:52 GMT -5
I tried to sand the inner part of the rim to improve braking but it didnt help much, any ideas?
Post by scooterpimp on Sept 27, 2018 6:42:03 GMT -5
Usually sanding/scuffing drum & shoes helps glazed , noisy brakes . Besides properly ajusted shoes/ cable . Thats about it. Make sure brake shoes are clean & not oily etc. Unless shoes are worn , then thats another story.
Post by KSR Moto on Sept 27, 2018 7:40:24 GMT -5
Usually sanding/scuffing drum & shoes helps glazed , noisy brakes . Besides properly ajusted shoes/ cable . Thats about it. Make sure brake shoes are clean & not oily etc. Unless shoes are worn , then thats another story. Is it a short term solution or it will last for a long time?
Post by dexameth on Sept 27, 2018 9:01:34 GMT -5
It will last as long as your pads are healthy. If your adjustment nut has to be really far in to activate the rear brakes, there's a good chance the pads are very worn and need replacing.
Post by SMALL CC TEK on Sept 27, 2018 14:07:24 GMT -5
A quick sand blast is a good idea . A tight set of brake shoe springs will kill the squeak most times !
