Post by kraine on Oct 1, 2018 10:48:44 GMT -5
I have a taotao thunder50 (qmb139) and the crankcase (long) broke where it connects to the frame on both the left and right sides. I am looking for a replacement but according to www.partsforscooters.com/151-231_Crankcase_left_type2?sc=34&category=133357 there are 3 different versions of this crankcase but I can only find 1, how can I tell which I need and can anyone point me towards an ebay listing or link for a site to order it from? Is there a way for me to tell if the oil pump gear is 33 or 47 tooth without taking it apart? Also will I need to order anything besides the left and right crank cases, gasket and new bushings?
Post by scooterpimp on Oct 1, 2018 11:16:38 GMT -5
Wow I only knew of short 10 inch or long 12 inch or Xiong cases’ can they supply measurements?
Post by kraine on Oct 1, 2018 12:48:36 GMT -5
Thats what I thought too, but partsforscooters is claiming there are 3 versions of the left case, they supply measurements for the only one i can find on their site the type 2, but I wasnt planning on pulling my scooter apart until the parts arrive since I have to do all my work in a parking lot
Post by gsx600racer on Oct 1, 2018 13:39:29 GMT -5
How many car's were you able to jump before it broke ?
Post by FrankenMech on Oct 1, 2018 15:37:18 GMT -5
Just get a replacement engine and keep the busted unit for parts.
Post by scooterpimp on Oct 1, 2018 17:45:45 GMT -5
FrankenMech has a good point , by the time you get cases , seals , gaskets & ? Your close to what an engine would cost. Just my 2 cents.
Post by kraine on Oct 2, 2018 0:41:20 GMT -5
not really, cases are 58$ and 30$, seals are 5$ each and i have the gaskets already, i ordered a full gasket set when i got my bbk because it only came with the head gasket, im seeing engine starting at 329$, and then ill have to swap my bbk and cam to the new engine, thats triple the price, and sadly i didnt get to jump any cars, some asshat pulled into the space i was parked in and smashed into my scoot and the center stand bent under and snapped the case
Post by GrumpyUnk on Oct 4, 2018 12:18:48 GMT -5
Post by dexameth on Oct 4, 2018 13:23:46 GMT -5
Hey guys, yes there are three sizes. Standard short case, standard long case, and the xtra long case found on the Icebear Maddogs (stretched Ruckus clones). If your mounting tabs broke off you'll need the right case found here and the left long-case found here. We don't have either the short case or the xtra long case in stock right now, so the ones you'll see linked will be the ones you want.
