utp9
Post by utp9 on Oct 6, 2018 3:48:52 GMT -5
I ordered a Chinese replica of a Dellorto PHBG 21mm carb off of eBay. This is for my 50cc moped, so I'm trying to adjust it so it runs smoothly. Following these: www.mopedarmy.com/wiki/PHBG_tuning_made_easy_(a_step_by_step_guide) instructions, I have been trying to tune the carb. However, my idle screw imgur.com/a/bG5DCm8 does nothing when turned in or out. Only when I turn my air/fuel mixture screw, does the rpm increase. The air/fuel mixture screw is acting like the idle speed screw as whenever I turn it in, RPM increases. To the point where it keeps increasing to the point where I can't turn it anymore. Am I doing something wrong or do I just have a faulty carb?
Post by geoffh on Oct 6, 2018 8:46:08 GMT -5
only trying to help,why fit a 21mm carb to a 50cc ? A stock carb is normally good enough.
utp9
Post by utp9 on Oct 6, 2018 10:17:49 GMT -5
only trying to help,why fit a 21mm carb to a 50cc ? A stock carb is normally good enough. Geoff I'm fitting a 75cc kit on it, so I want to get the jetting somewhat correct beforehand
