Post by stancejontland on Oct 9, 2018 0:45:07 GMT -5
Heres a link to my YouTube video. Tried screwing the adjustment on the throttle but it wont get rid of the play. Any ideas? youtu.be/OP2U7zCmAUY
Post by gsx600racer on Oct 9, 2018 0:55:19 GMT -5
You should have some adjustment at the carb as well as at the throttle.
Post by pinkscoot on Oct 9, 2018 11:04:58 GMT -5
You want a little play in it so that when you turn the handlebars hard each way it doesn't pull the the cable and increase your RPM's.
Post by aeroxbud on Oct 9, 2018 17:21:28 GMT -5
Like said above there should be an adjustment at the carb. You will probably have to push back a rubber boot to get to it. That free play is within what most manufacturers would recommend. Though I don't like it as well.
Post by stancejontland on Oct 10, 2018 2:36:04 GMT -5
i had to cut my throttle cable to fit the new carb. idk if i can adjust at the carb
