Post by katt on Oct 10, 2018 20:51:06 GMT -5
There's no data about this in any manual i wonder whats the normal running temperature for GY6 QMB139 in particular?
Does anybody have temp gauge installed and can give your temp readings ?
Post by Lucass2T on Oct 10, 2018 22:08:00 GMT -5
Do you mean oil temp, egt or cht?
Post by katt on Oct 11, 2018 1:18:05 GMT -5
Oil or cylinder head temp.
Post by 90GTVert on Oct 11, 2018 5:57:49 GMT -5
Post by katt on Oct 12, 2018 0:55:21 GMT -5
How come you don't overheat and warp when it goes that high 250F is 120C.
Post by 90GTVert on Oct 12, 2018 10:46:06 GMT -5
The temps sound high if you're used to watching coolant temp in liquid cooled machines, but they're common in air cooled engines.
Post by gsx600racer on Oct 12, 2018 18:06:37 GMT -5
How come you don't overheat and warp when it goes that high 250F is 120C. Warping could occur under special circumstances. In this case when overheating happens, pistons and cylinder walls are the casualties.(seizing)
Post by gsx600racer on Oct 13, 2018 0:19:40 GMT -5
I like the technical way this guy measures the oil temp on his scooter and where the temp runs at.
"oil temp seems to be good, it seems to maintain itself at being a cow"
Post by katt on Oct 13, 2018 0:31:41 GMT -5
This guy is nutjob i've seen his channel before he builds all kind of crazy setups, but he makes money of youtube so its a business.
Post by gsx600racer on Oct 13, 2018 0:43:10 GMT -5
This guy is nutjob i've seen his channel before he builds all kind of crazy setups, but he makes money of youtube so its a business. He knows how to build scooters that go fast. You need to step up your game.
ratdog
Post by ratdog on Oct 13, 2018 14:50:53 GMT -5
Just wondering... do you have a head temp sensor and gage? If you had a proper head temp sensor, you may find your engine running over 360 degrees.
The biggest problem with “running” temp is where and how the temp is taken. More important is that the most important temp to know is head temp. The upper end is where your engine is going to melt
Post by gsx600racer on Oct 13, 2018 15:06:32 GMT -5
Just wondering... do you have a head temp sensor and gage? If you had a proper head temp sensor, you may find your engine running over 360 degrees. The biggest problem with “running” temp is where and how the temp is taken. More important is that the most important temp to know is head temp. The upper end is where your engine is going to melt Iv suggested that here. 49ccscoot.proboards.com/thread/21437/adding-temperature-sensor?page=3But as usual it falls on deaf eye balls.
ratdog
Post by ratdog on Oct 13, 2018 16:59:29 GMT -5
Sorry, didn’t read that thread. So forget what I said it has been handled.. imho oil temp is as useful as tits on a bull, but heck, what do I know?
Post by 90GTVert on Oct 13, 2018 17:38:16 GMT -5
I pay basically no attention to my oil temp on the TaoTao. I didn't even bother to put the gauge back on after re-arranging my bars. It's basically good just to know that, yes these things run high oil temps and that oil coolers help. The CHT actually shows that oil coolers help just fine on it's own though.
Post by scooterpimp on Oct 13, 2018 21:16:03 GMT -5
Oil temps do run high on these little engines , i usually change oil often due to heat breaking it down faster than usual . It helps me sleep at night..lol.
